D4 light flashing when key is set to before starting the car.
Old Jun 24, 2006 | 06:41 PM
jrcastro's Avatar
Default D4 light flashing when key is set to before starting the car.
i noticed my 92 accord d4 light blink when i have the ignition is switched to the on position. But when i start it it does not appear. It does not happen all the time only sometimes.
Is this an issue i should worry about? My car runs good, no shifting problems at all. Has anyone heard of this happening?
Old Jun 24, 2006 | 07:00 PM
Chiovnidca's Avatar
Default RE: D4 light flashing when key is set to before starting the car.
Does it have a trouble code stored?
Old Jun 24, 2006 | 07:27 PM
jrcastro's Avatar
No i don't see any codes.
Old Jun 24, 2006 | 11:30 PM
deserthonda's Avatar
have you done anything with the computer ?? chipped?? swapeed ?? is everything stock???
when you say you don't see any codes are you jumping the service connector??
Old Jun 25, 2006 | 11:58 AM
jrcastro's Avatar
ORIGINAL: deserthonda
I have not done anything to the computer, everything is stock & I have not jumped the service connector. I don't know how to.
Old Jun 25, 2006 | 12:03 PM
To read the code you need to jump the SC ( service connector) a blue plug with 2 wires located under the dash below glove box . by the kick panel..
use a paper clip, jump the wires together, turn the ignition key on and read the blinks on the instrument cluster
a longer blink = 10
a short bilnk = 1
let the pattern repeat 2 -3 times to make sure that there is only one code stored and also to make sure you are reading it correctly..
if you go the DIY section OBD trouble codes click o the link , and read ,,, also if yow scroll all the way down and there is a description of the codes your car is OBD1 codes..
csh217
Jun 17, 2014 05:53 PM
Sublime69
Jan 10, 2012 10:26 PM
jwk8199
Sep 23, 2010 03:47 PM
spesler
Jun 3, 2010 04:05 PM
