D4 Light Won't Stop Blinking
Old Oct 19, 2007 | 01:24 PM
falkore24's Avatar
Default RE: D4 Light Won't Stop Blinking
Prizma, you need to read the error code via DH's directions above. Trannies can have a whole slew of issues and yours may not be the same problem as PhillipK's.
Old Nov 26, 2007 | 03:17 PM
hcg
Please HELP! I have same problem, D4 starts blinking on 95 Accord after driving some and when it does transm gets uneven even though when I turn the engine off it seems to reset and get no blinking until drive again for a while. Jumped the SC connector while engine on and got code 4 (speed sensor) but the speedometer works well so not sure if it is the problem. Does anyone have any suggestions?
Old Nov 26, 2007 | 03:36 PM
sir_nasty's Avatar
does your cruise control work? Did you read the code more than once to make sure that it's a code 4?
Old Nov 26, 2007 | 04:36 PM
hcg
yes the cruise control works and read the code several times, code 4 for sure
Old Nov 26, 2007 | 04:51 PM
sir_nasty's Avatar
Where did you find/read the code from to determine that it points to a speed sensor? was it a CKP Sensor by chance?
also, since we've got multiple people on this thread please post your car info in your signature so it's always there
Old Nov 27, 2007 | 05:24 AM
hcg
First of all, thanks a million! No, used the codes found in the "Automatic Transmission Diagnostic Trouble Codes" for Honda found in the troubleshooting zone of http://techauto.awardspace.com/transmission.html
Code 4 reads speed sensor.
The code 4 for CKP sensor (I found) is when the check engine light is the one that blinks, in my case the D4 light is the one blinking. I do not think the problem is the speed sensor (VSS) since the speedometer works well and got no diagnostic code from the check engine light (should show code 17 for VSS). The D4 ususally begins to blink when shifting from 3 to 4 gear and once the blinking begins all shifts become erratic and even the engine idles uneven when in drive (accelerates and deaccelerates by itself, if place transmission in neutral idle returns to normal).
Old Nov 27, 2007 | 12:14 PM
  #17
sir_nasty's Avatar
It almost sounds like a TCU issue. I wouldn't condem it just yet, someone will give some additional advice but it all sounds way to random and sporadic to be a VSS (especially if your cruis and speedo work fine). Do you have any junk yards nearby? Have you already tried resetting the ECU?
Old Nov 27, 2007 | 01:00 PM
  #18
deserthonda's Avatar
code 4 . lock up clutch not engaging,,
chk all the wiring and connections at speed sensor,
also, chk the same at lock up solenoid..
the link you have shows a way to test solenoids.also you might want to remove the solenoids and clean the solenoid screen and passages in tranny, blow in there with some compressed air ( not full blast )
try this and keep us posted
Old Nov 27, 2007 | 01:07 PM
  #19
sir_nasty's Avatar
see, I knew if we just waited someone would come along that new that code! Forget what I said listen to deserthonda (seriously) he's the man!
Old Nov 27, 2007 | 02:56 PM
  #20
hcg
Thanks, I“ll give it a try and let you know!
