To da Track
Old May 14, 2006 | 05:17 AM
legionofone's Avatar
Default To da Track
ok so i put my car in the track for the first time today... it was horrible... i ran very fast but couldent get traction... i know if i could of caught... i would of ran high 15s or low 16s... even after white smoking my tires for 200 feet i still got up to 84 mph in the quarter running a final time of 21 seconds... anyone got any tips for a person with some skinny tires trying to run a quicker quarter... (tires are 205/60/r15)
Old May 14, 2006 | 05:47 AM
marbro's Avatar
Default RE: To da Track
get wider rims? or just spend some money for two 13inch 8 or 9 inch wide with slicks. Otherwise its a situation of learning what point you can rev it to when you pop the clutch without spinning the tires... tires that arent wide means you wont have traction if you have enough power..... even though..... my car does the 1/4 in the mid 16's........ with an auto....
and if your tires have enough tread worn off, it wont matter anyways
Old May 14, 2006 | 11:23 AM
mbo1985's Avatar
What RPM do you drop it from? Bigger tires is the best way to fix things, but practice and fine tune your launch to find the best way.
I've also heard of traction bars for civics, does anyone know of any for accords? This would surely help keep those front tires on the ground.
Old May 14, 2006 | 02:52 PM
yeh... i was dropping it at 3 2 and even 1 at 1 it only shudddered a bit before it launched... that was another question... when it did my burnout it started good then it just starts to shudder ALOT i never had this problem before with any other car... i dont exactly understand it... (this is still my first manual)
Old May 14, 2006 | 03:35 PM
marbro's Avatar
shuddered as it it was like the wheels bouncing up and down? if its doing that, then you need better shocks and springs. If you can manage to find a poly rear motor mount, that will help on your launch as well, theres also the option, of this little high pressure shock you can get that mounts to the engine and the firewall to prevent the front to rear engine movement.
And check your motor mounts in general, they could be failing.
As for traction bars, there arent any that i know of off hand.
Old May 14, 2006 | 10:18 PM
7thGen's Avatar
My 03 Accord 4cyl 5spd 4 door got 15.6s at Tulsa Raceway last year. My friend got one run down to a 15.4. The track was running slow that night also. I did have 235/45r17 all seasons on it. The launches were at 3k and no clutch drop.
Old May 16, 2006 | 01:56 AM
damn nice yeh i wanna get some drag slicks was ur stuff stock? i know mycar can run 15s but i just couldent get traction...
Extremespeed
West
Oct 21, 2012 11:59 PM
Extremespeed
West
Feb 23, 2012 02:32 AM
Extremespeed
West
Dec 13, 2011 02:03 AM
honker3
May 25, 2011 12:11 AM
Shocker
May 15, 2005 11:43 PM
