Dead Cylinder 1994 Honda Accord EX 4cyl F22B1 engine
Old Jul 19, 2020 | 06:16 PM
Ryan Haines's Avatar
Default Dead Cylinder 1994 Honda Accord EX 4cyl F22B1 engine
Cylinder 3 is reading dead on my compression gauge. My timing belt snapped the other day and the car died. And like a dummy I kept cranking on it. I now know that it is an interference engine, and that this most likely resulted in valve damage.
But on the off chance, could I be getting a dead cylinder from the engine being out of time? Please help I've spent two days and more money than I wanted, and still have a busted ride.
Old Jul 19, 2020 | 07:49 PM
Seanjordan20's Avatar
How are you checking compression with no belt
Old Jul 19, 2020 | 07:55 PM
Sorry. I forgot to specify. I replaced the timing belt and balancing shafts belt. All my timing marks were lined up correctly.
Old Jul 19, 2020 | 08:24 PM
If your other cylinders have decent compression, then you likely did some valve damage on #3. You also said the belt was installed with the marks lined up, so if you were off a few teeth with improper installation, you would still get some compression on #3.
Old Jul 19, 2020 | 08:30 PM
shipo's Avatar
At this point your next best option is to pull the head, have it reconditioned, and reinstall.
Old Jul 19, 2020 | 08:32 PM
+1. I agree
Old Jul 20, 2020 | 04:26 PM
Yes. If your valves were not damaged, then being slightly off-time would affect all cylinders equally.
Old Jul 28, 2020 | 07:58 PM
nomad2020's Avatar
sounds like bent valve (s) to me ,
Old Aug 1, 2020 | 11:12 AM
That's what I was afraid of. Just wanted a few opinions before I went through the work.
Old Aug 1, 2020 | 12:10 PM
Depending on the mileage of your engine, you may want to consider replacing the engine.
I remember having the option to buy a low mileage engine for my 95 MT accord for ~$250 with 40K miles. It will probably be less expensive vs rebuilding the head.
It just depends if you want or have a cherry picker (or other lifting equipment to replace the engine. car-part.com was the site where I found that engine, but sold the car before pulling the trigger to replace my 300K mile engine. If you go this route, try to verify the donor vehicle was hit from behind and that it was hit, because it means the engine was likely running. If there is no visible damage, then you aren't even sure the engine was running or it was flooded, etc. Also ask if the junkyard will do a compression test in front of your or even better a leak-down test on each cylinder.
bluedemon
Mar 24, 2012 06:58 AM
masterjp92
Jul 27, 2011 07:04 AM
HondaAccordEX94
Nov 1, 2010 12:34 PM
erikhans
Apr 14, 2009 07:35 PM
honda help
Apr 25, 2007 08:34 PM
