Dexron III ATF
Old Apr 28, 2016 | 09:17 PM
mtill58513's Avatar
Default Dexron III ATF
I've got a seal leaking or a bad half shaft on my 2000 v6.
It's slinging a little ATF on the driver's half shaft. I'm putting it in the shop Monday afternoon and am checking fluid level to make sure it doesn't get too bad. I have some O'Reilly ATF which is a Dexron III substitute. Can I use this stuff in my car or should I stop at a store tomorrow and get the Honda official stuff? Does it even matter? My owners manual says use the Dexron stuff just as a temporary substitute and swap all the fluid out afterward. Any help would be greatly appreciated. Thanks.
Old Apr 28, 2016 | 10:09 PM
shipo's Avatar
It matters; BIG TIME. Whatever you do, do NOT pollute your transmission with Dextron III.
Old Apr 28, 2016 | 10:24 PM
mtill58513's Avatar
OK. Thanks for the heads up. I may just swing by the dealership tomorrow after work and get the official stuff.
moey
May 22, 2011 10:43 AM
brokanic
Dec 6, 2010 01:22 AM
johnb06accord
Feb 5, 2008 12:00 AM
rcy
Apr 14, 2007 09:50 PM
95exr
Jun 11, 2006 10:56 PM
