Did a SAM Analyis on my 98 Accord EX w/ 102k miles
hello all. very minimal knowledge on cars etc so I thought I would look to you guys for advice. I assume the SAM tests are pretty accurate? Does anyone mind telling me how critical the following issues are and if they are really as important as the analysis indicates. Also, if they are important, how expensive to have it fixed? Thanks in advance!
P0702-ENG
Damaged TCM(?) with an internal failure
26-1 AT 3rd Pressure System Failure
12-ABS
Malfunction with the ABS Wheel Speed Sensor
81-ABS Continuous TCS Operation
Vehicle Stability Assist Modulator Control unit has a fault and must be replaced.
81-ABS CPU/VSA Control Unit and ROM/RAM Diagnosis
17-6 ENG
P0702-ENG
12-ABS
17-6 ENG
Interesting results.... I don't know all of the issues off hand.... the ABS unit appears to have failed completely which means that you no longer have ABS, the brakes will work but will not bring the added function/safety of an ABS system, not to mention one of the speed sensors that helps it make its decisions appears to be bad anyway. The TCM issue I've heard of but can't think of.... My brain is fried right now....
Long and short: ABS is expensive to repair but important for vehicle safety and high speed braking....
no probs that i notice...just saw the maintenance req light and decided i would see what the prob is....would i be ok to drive like that? i assume so since people didnt use to have ABS...but i dont want to be driving one day and not have brakes
The ABS and regular brakes are separate systems, so you can drive without ABS and have no worries about normal braking.
Just be aware that you can lock up the brakes, since the ABS system will not kick to prevent that.
ctgulick
Jul 1, 2009 12:45 AM
