dipstick?
Old Aug 3, 2006 | 05:46 PM
miki's Avatar
Default dipstick?
Hi....
I have a stupid question. Im new to this forum so if this question has been asked before i apologize.
Anyways I decided to change oil on my car at mr lube. I went home and the next day I checked to see if everything was fine and i checked the dipstick measure. It was overfilled. I cleaned the it with some cloth and tried it again, nothing changed.
I check it again the next day and this there was not enough oil( i let the car sit for couple minutes and then check) . I don't know what to do , every time i check i get different result.
They put castrol (not sytetic) oil and I belive FRAM filter ( i know fram is bad but its the only one they had for accord)
My car is 05 accord v6.
Anyone else had experience with this problem.
Thank you in advance!!!!!!
Old Aug 3, 2006 | 08:04 PM
lightshow's Avatar
Default RE: dipstick?
make sure the car has been sitting. pull the dipstick clean it stick it back in all the way then pull it out quick. turn it over to the side that doesnt have the notches and shine it in the light. then remember that spot and turn it over to where the measuring lines are and see how full it is
Old Aug 3, 2006 | 08:23 PM
sir_nasty's Avatar
I've never personally had issues with Fram filters but that's just me... the biggest thing you need to do to get an accurate reading is make sure your car is level and not running...
Old Aug 3, 2006 | 09:19 PM
deserthonda's Avatar
sir nasty hit it on the head,make sure car is on a level surface and car has been shut off for a bit , give a chance to all the oil to drip down back to the pan. also make sure that the dipstick is fully inserted every time you chk oil level
Old Aug 4, 2006 | 02:20 AM
Ive never had a problem with a Fram Filter my self so I don't know where someone might have got that information from..
Welcome to the forums MIKI [sm=americanasmiley.gif]
Old Aug 4, 2006 | 04:27 AM
lightshow's Avatar
i think its the comparison to how they used to be made. they were arguably the best filter out there. but then the company that owns it now bought it and lowered the quality substantially. i use the tough guards though, i dont wait long enough for the filter to be a problem and i like the grippyness
Old Aug 5, 2006 | 10:34 PM
miki's Avatar
tx for your help. I decided to take the car back to the shop. There was a small leak on filter ( probobly because they didnt tigthen it enough or because they hire 16 y/olds as professional mechanics ) which drain oil every now and then ( thats what they tell me ). The car is fine now,,, Agein thax for you help!!!!
Old Aug 5, 2006 | 10:42 PM
RTexasF's Avatar
Super Member
Fram filters suffer from the cheapest construction of any filter made. Some Honda filters made by Fram are just as bad. They do work but in the future just ask for a different brand. It's just a matter of there are better products available for the same money (or less) spent.
Glad you got the boo-boo fixed.......installer error....again!
Old Aug 5, 2006 | 11:22 PM
fireballer44's Avatar
In the midst of all this oil filter debate, I thought this might interest everyone. Check out the link, it is a pretty in depth comparison of many filters.
Engine Oil Filter Study
Old Aug 5, 2006 | 11:48 PM
This is a good starting point for the members to save in there favorites area, this way they can check out the opinions of someone who must have tried them before...
WheelbrokerAng [sm=americanasmiley.gif]
