distrbutor replacement
Old Feb 22, 2011 | 05:07 PM
Glad you solved the problem.
Its kind of strange that the injector would go bad when doing a distributor change. They are not related.
How did you figure this out?
Old Feb 22, 2011 | 11:06 PM
bigbadwolf078's Avatar
i pulled the plugs too a compression check and #4 looked brand new and didnt smell like gas at all....still had the fuel rail from doing my swap and just switched it out and it fired right up....crazy how it worked out tho but atleast it runs
Old Feb 23, 2011 | 11:45 AM
It's easy to get a fuel rail/injector leak that might disable an injector. Could that have happened?
Old Feb 23, 2011 | 11:25 PM
no distrubtor was bad but wait gets even better now just found out the head is cracked in the motor i just put in it....so what can i put in instead of an f22a1 cuz im done with that ****.....any other motor bolt in and use my harness?
s4m222
Dec 22, 2009 12:31 PM
