distributer replacement
Old Jul 21, 2012 | 02:59 PM
puttputt's Avatar
Question distributer replacement
I have a 92 accord with a code 4 CEL. I was told I need to replace my distributer cause it has a bad crank angle sensor in it. It has a external coil, I have another distributer that came off a 91 accord but has an internal coil. Can i switch them without changing the wiring? Or will i have to redo my coils positive & negative wires?
Old Jul 21, 2012 | 03:24 PM
I would suggest doing a resistance check on that sensor using a volt meter. You would also want to do the same resistance check at the ECU to see if the resistance is the same. Carefully inspect the wiring inside of the distributor as well.
The electrical connectors are different, so you would have to do some wiring work. To make the distributor swap less difficult, I would get the identical distributor. You should be able to find a cheap one at a junkyard.
There is also a ground on the thermostat housing that you may want to unbolt, clean with a wire brush or sandpaper, then reattach. That is an important ground for the ECU.
Old Jul 21, 2012 | 03:31 PM
puttputt's Avatar
thanx i will give it a try. until i get this fixed my car is stuck in limp mode. cant go over 3500 rpms makes goin from 1st to 4th gear not very exciting(bummer)
live2rice
Aug 1, 2008 02:55 PM
cordo88
Apr 16, 2008 09:48 PM
live2rice
Mar 8, 2008 06:19 PM
cbinva
Feb 10, 2008 10:36 AM
g1teg
Oct 3, 2006 05:01 AM
