distributor replace
Old Feb 26, 2010 | 03:48 PM
96a-ccord's Avatar
Default distributor replace
I am changing the distributor in my 96 honda accord ex and i was wondering if any one could tell me any tricks or things i should do or look out for while doing this procedure
Old Feb 26, 2010 | 05:58 PM
kris_loehr's Avatar
The dist. can go into ways. It should seat easily if not it may be off 180 degrees. Just pay attention to the rotor positions. Make sure it has an O ring on the shaft.
Old Feb 26, 2010 | 07:20 PM
jimnomod's Avatar
Get/borrow a timing light so you can set the spark timing correctly.
There's a blade on the end of the distributor shaft - it fits into a slot in the camshaft. Look & notice that it's off-center. It might be possible to put it in backwards if you hammer it in hard enough. Just be sure it lines up correctly & it'll slide right in.
chingalong
May 26, 2011 11:14 PM
gearshift
Apr 17, 2010 07:30 PM
gearshift
Nov 11, 2008 09:24 PM
dacecil
Jan 27, 2008 05:29 AM
LinX
Nov 1, 2005 12:38 AM
