Distributor Saft Seal leak. Replacement?
Old Oct 20, 2011 | 09:16 PM
nickmg555's Avatar
Default Distributor Saft Seal leak. Replacement?
So i removed my dist. today to replace the o-ring because i had an oil leak all over the engine from under the dist. and i found oil inside. all the contacts were covered in oil and so messy i cant believe my car was still running. so i dismanted it all and without a doubt i have a bad internall shaft seal. its very easy to replace but no local part stores have them and they are about $20 with shipping online. Does anyone know anyone who may carry these? or a cheaper source. Thanks.
Old Oct 21, 2011 | 06:34 PM
What year are you working with here...4 or 6 cyl?
See if this might help
“ honda-tech.com/showthread.php?t=2214402 “
Old Oct 25, 2011 | 01:07 PM
nickmg555's Avatar
Just got the Seal today. Replacing it is easy but as for removing the oil. Engine degreaser in the dist. Cap? That would clean it out nicely the rest I will wipe out but not sure if the degreaser will hurt the metal contacts.
Old Oct 25, 2011 | 03:39 PM
UhOh's Avatar
Acetone dissolves oil and evaporates very easily w/o residue from the acetone itself ,,, @ hardware type store, Lowes.
Flammable like gasoline so use outside.
I'd like to know how it works on distributor, too.
Old Oct 25, 2011 | 04:00 PM
nickmg555's Avatar
Acetone is also known to damage/melt/dissolve plastics.
Acetone + plastic dist. cap, rotor, and plastic housing = bad news
It would be good on metals but horrible for plastic, acetone and MEK do a number on plastic.
I will just use the degreaser. it degreases the metal engine block with no corrosion so i cant imagine it being a problem on metal contacts.
Old Oct 25, 2011 | 04:38 PM
Electrical contact cleaner would probably work best. Brake cleaner may also do the trick. Then let it completely air dry or use compressed air from a can or something.
Yeah, you don't want to use acetone. I used acetone to dissolve huge packing foam and plastic before.
Old Oct 25, 2011 | 05:15 PM
nickmg555's Avatar
I just got done replacing the seal i couldnt find the degreaser so i used paper towels which worked fine. all is well. i still need to degrease the engine though to make sure the oil leak is gone under the distributor
Frugalhondaguy
Apr 15, 2015 12:49 PM
Jcaleno
Dec 11, 2010 06:10 PM
Jcaleno
Feb 10, 2009 11:50 AM
strat
Oct 10, 2008 11:51 AM
