Distributor Oil seal replacement 2000EX 4cyl
Old Apr 15, 2015 | 11:10 AM
Frugalhondaguy's Avatar
Default Distributor Oil seal replacement 2000EX 4cyl
I ordered the O-ring and seal for my Accord. I noticed that on the 2000
Accord that it is difficult to remove the roll pin in order to pull the shaft. I see that most are beating the pin out with a punch and hammer. I am thinking about buying an Arbor press from Harbor Freight for $38.00 and use that to push out the pin.
Q1) Of the people that did replace the seal, would the press have been a better option?
Q2) Could you determine if the seal was leaking when you replaced it?
I was looking at a video from "Eric the Car Guy" and he said that if there isn't any oil inside the cap, the oil leak is at the O-ring. If I could confirm that, I wouldn't replace the seal.
Old Apr 15, 2015 | 12:36 PM
Q2...
If you don't have oil INSIDE the distributor, then the shaft seal isn't leaking. Think about it; if that seal is leaking, the only place for the oil to go is inside the distributor. And likewise that oil-seal around the distributor shaft is the only place for oil to come from INSIDE the distributor.
The O-ring around the base of the distributor, would leak outside of the distributor body. The oil would leak out right there & run down the end of the cylinder head, similar to a valve-cover gasket leak.
Old Apr 15, 2015 | 12:49 PM
Thank you Jim, and your right, if I had taken the time to think about it, I wouldn't have had to ask the question. Just an old man whose mental facilities are failing me. You have put me on the right path brother.
Frugalhondaguy
Apr 13, 2015 05:18 PM
Frugalhondaguy
Apr 1, 2015 06:25 PM
Jet sitter
Mar 31, 2012 12:34 PM
nickmg555
Oct 25, 2011 05:15 PM
