P1157 - 2007 Accord Sedan LX 2.4
Old Apr 15, 2015 | 10:05 AM
sjlabash's Avatar
Default P1157 - 2007 Accord Sedan LX 2.4
I am assisting my brother-in-law who has a 2007 Honda Accord LX 2.4L 5 speed manual sedan. CEL is on with DTC P1157. A mechanic already replaced the upstream (Bank 1 sensor 1) LAF sensor, but the CEL stayed on. He put the old sensor back on. The part was purchased at NAPA and I believe it was Denso. I would like to check the wiring to the ECM and connectors, but need to know the ECM location and ECM connector(s) pinout(s), specifically the LAF sensor pins. We do not have a manual.
Thank you,
Sam
Old Apr 15, 2015 | 12:40 PM
Welcome!
This "new-member" area is pretty much for welcome & introduction posts. So I'll move this over to General Tech where the real questions belong.
Old Apr 15, 2015 | 12:58 PM
sjlabash's Avatar
Thank you Jim. I had trouble finding where to submit a new posts, but was able to see a New Post link in this area. Thanks again,
Sam
Old Apr 15, 2015 | 03:17 PM
Following link suggests a wiring or connector fault is likely.
P1157 2008 Honda Accord Air/Fuel Ratio Sensor 1 Range/Performance Problem OBDII Engine Light Trouble Code | Engine-Codes.com
You can purchase a download manual w/ all info needed to locate connectors and wires from automanualsource.com for $22.
tony03accord
Feb 23, 2015 08:29 AM
rahulvasudeva
Sep 14, 2009 10:38 AM
GT Racer 23
Nov 21, 2007 10:22 AM
swol_je
Jul 31, 2007 01:05 PM
