distributor swap
Old Jun 12, 2013 | 04:43 AM
Phobia's Avatar
Default distributor swap
To start off this isn't my car :P brother in law anyways long story short his motor blew f22b2 and he didn't have much money to fix it and I just happen to know someone with a low millage f22b1 in storage so we picked it up supper cheap with ecu and distributor "new". We swapped it out on Saturday and was 95% done but then we got to the distributor.... the plan was to use his old one and do the timing and be done with it. Problem is we don't know what happened to the old f22b2 distributor lol he said he didn't think we would need it and misplaced it the new f22b1 distributor is internal coil but the wiring in his accord is set up for external, I've tried searching but almost everyone uses the f22b2 distributor rather than trying to rewire the f22b1..... I know it sounds like a big task to ask for but I myself don't know much about wiring that's why I had planned on using the old distributor and coil but things chance lol any help or if anyone knows another thread that I may have missed it would be greatly appreciated. This is literally the only thing keeping us form finishing and I know what most of you are thinking, buy a new or used one but that's the first thing people seem to take form the junkyard and a new one online is expensive, ether than or he's going to have to buy a used one on ebay $70
1997 accord lx
Wires going to external coil plug
Black-Yellow
Green
Yellow
Wires going to distributor small plug
Yellow
Blue
Wires going to distributor large plug
Black
Yellow
Green
Yellow - Green
Motor 1997 accord dx
One large plug
Black - Yellow
Black
White
White - Green
Blue maybe green?
The color is faded on the distributor maybe its green maybe blue idk
Old Jun 12, 2013 | 09:13 AM
I've moved this to General Tech for better answers.
Old Jun 12, 2013 | 09:36 AM
Phobia's Avatar
sorry I didn't realize I had posted in the wrong section, but thanks
Old Jun 12, 2013 | 10:21 AM
Phobia's Avatar
ok so I did a bit of research this morning and im not 100% but I was reading that I need to ether splice together or put a 30 amp fuse between the coil wires black-yellow and yellow, I will not be needing the green wire but im still not 100% on this and im still in the dark about the rest of the wires
Old Jun 12, 2013 | 10:38 AM
Roader's Avatar
Is the F22B1 from a '95 - '96 car? Your '97 OBD2 car is looking for a couple of sensors behind the crankshaft pulley. If the F22B1 is an OBD1 engine from a '94 - '95 car it won't find them.
Easiest is to get another external coil distributor. I bought one a few weeks ago at a junkyard for $30 and they threw in the external coil. That way there's no rewiring needed. If you want to stick with the internal coil dizzy then some rewiring is needed. There's quite a few forum posts out there on how to do this. Here's a couple:
cb7tuner(dot)com/vbb/showthread.php?t=81303
board(dot)accordtuner(dot)com/showthread.php?42261-External-to-Internal-coil-help
Something about shorting the YEL and BLK/YEL wires together using a 30A fuse in the connector to power the internal coil. Looks easy enough.
Good luck.
Old Jun 12, 2013 | 12:50 PM
Phobia's Avatar
I believe both motor and car are obd2 and 97. I saw a few posts about converting them but to be honest im just going to tell him to buy an external and sell the new internal one + im no electrician so yeah lol
Jrmemo
Jan 27, 2013 07:41 PM
hondahead23
May 9, 2011 08:55 AM
mfskarphedin
Jun 6, 2010 09:33 PM
reeferman74
Feb 13, 2007 10:04 AM
