Do I Have R12 or R134 A/C System? '93 Accord
Old Mar 25, 2014 | 07:38 PM
JQuinn's Avatar
Default Do I Have R12 or R134 A/C System? '93 Accord
Hello, I'm new here, but I've been getting into DIY car maintenance a lot.
The A/C stopped blowing cold on my '93 Accord wagon. My wife drives this car and went through half a summer already with no A/C. This summer, it's time to fix it.
My question is, how can I tell if I have the R12 system or if my car was converted to the R134 system? What parts or pieces would I look for?
I greatly appreciate any help! Thanks.
Old Mar 25, 2014 | 07:45 PM
Look at the fittings on the high and low side......if done right, conversion - the 134 look more like an air hose connection - no threads on the outside. If there are threads on the outside of the high and low fitting...might be r12.
Old Mar 25, 2014 | 08:59 PM
JQuinn's Avatar
Thanks.
With the cap off, there are threads on the inside of the fitting in the image below. I don't know if this is the high or low line. I can't find the fitting on the other line. In the picture you can see that line just comes up then curves back down. It looks like it goes into the condenser.
I also found the sticker for the AC. It says R12, but that doesn't tell me if a conversion was done.
So, are there other parts changed in a conversion besides the fittings, or do you just put the R134 refrigerant into the same system?
Old Mar 25, 2014 | 09:16 PM
djkurious's Avatar
The other fitting if I am not mistaking is behind the headlight.
If you don't know if it has been converted or not, I suggest having the system evacuated. It will have to be evacuated anyway before refilling with R134 or R12 to remove moisture and/or air.
93Accord2.2
Aug 18, 2013 04:30 PM
acesn8s
Jan 6, 2013 09:35 AM
blakem
Aug 9, 2012 08:51 AM
carl1864
Jul 11, 2012 06:53 PM
davidg99
May 5, 2011 11:59 PM
