Do I have wide band or narrow band?
Old Dec 31, 2008 | 05:48 PM
jdwilson4's Avatar
Default Do I have wide band or narrow band?
2003 honda accord v6 Auto
Dealer doesnt know... im assumeing its a narrow band oxy sensor..
if its indeed a wide band sensor, can i pull an A/F reading off the obd2 port using obd2 scanning software??
Thanks
Old Dec 31, 2008 | 11:47 PM
hondadude's Avatar
Default RE: Do I have wide band or narrow band?
Yes if the scan tool supports OBD2 parameters; the O2 sensor is a federal required sensor reading.
Old Jan 1, 2009 | 01:10 AM
finch13's Avatar
And no, you likely have a narrow band (standard) O2 sensor, the only exception would be if you have a hybrid or a ULEV-certified engine. But, nonetheless, you can pull A/F readings from both.
Old Jan 1, 2009 | 01:46 PM
jdwilson4's Avatar
ORIGINAL: finch13
actually i do have the ULEV certified engine, forgot to mention in original post, so i can pull wide band readings from odb2 port ??
Old Jan 1, 2009 | 06:56 PM
finch13's Avatar
With a scanner that can do realtime datalogging you can.
Starting in the 98-02 Accords with ULEV F23A4 engines, they used a wideband O2 sensor and a 32-bit Powertrain Control Module (computer) to cinch down on emissions by giving the computer more accurate information to adjust the fuel and spark supplies. Given that your engine is ULEV, you probably have a wideband O2 sensor, an easy way to find out would be the price. An OEM narrowband is usually about $100 or so and a wideband would cost $200+ from a dealer.
Wideband readings are usually a three digit (xx.x) number, which only the air number of the ratio is given, i.e. 14.4, which, in turn, would really be 14.4:1 or a perfectly balanced stoicheometric mixture in terms of dimensional analysis in chemistry.
Old Jan 1, 2009 | 08:36 PM
jdwilson4's Avatar
thanks.. ill call dealer and double check on price, do you know of any good odb2 dataloggers off hand? was considering buying the auto enginuity one, it seems to be able to log o2 sensor voltage(lambda?) but not display an actual a/f ratio, does the ecu just see lambda and convert that to an a/f ratio?
Old Jan 5, 2009 | 12:42 PM
falkore24's Avatar
They made the 7th gen V6 in a ULEV certified version?
Old Jan 5, 2009 | 01:41 PM
finch13's Avatar
I dont stink so... I cant find anything on it. It may have qualified though, because the J35A3 I have in the MDX is ULEV, but only has the window stickers for it.
4dooraccordex
Nov 9, 2009 11:44 PM
doop
Aug 24, 2009 12:03 AM
tony@sickaudio
Feb 6, 2008 03:49 PM
Goldnknight22
Aug 15, 2006 11:02 AM
tjones
May 24, 2006 09:56 AM
