Does AC Leak Sealer work?
Old Apr 26, 2007 | 09:09 PM
Dshow's Avatar
Default Does AC Leak Sealer work?
I have a '94 Accord LX that after I charge the AC system with Freon, it will last a couple of weeks before it starts blowing hot air again. Does the AC leak sealer/freon combination work or should I go straight for the dye to try to figure out where the leak is?
Thanks- Dshow
Old Apr 26, 2007 | 09:11 PM
sir_nasty's Avatar
Default RE: Does AC Leak Sealer work?
that sealant stuff may work for a while but ultimatley it's just going to clog crap up.... go straight for the dye and fix the problem right the first time
Old Apr 26, 2007 | 09:16 PM
deserthonda's Avatar
Do Not even think about putting stop leak in the a/c system.. you will turn what could be a cheap and easy job into an expensive and long job.. The expension valve plugs up real easy
once you put freon in then put dye into the system, it will show you where the leak is at .. if no leak is visible in the engine area . it could be leaking at the evaporator ,
Old Apr 26, 2007 | 11:25 PM
Dshow's Avatar
Thanks for the feedback, I will go the dye route.
Old Apr 27, 2007 | 10:18 PM
Chiovnidca's Avatar
ORIGINAL: deserthonda
Yep, the stuff seals up expansion valve real good. Too bad that's not a good thing.
EBK142
Jul 20, 2009 09:10 AM
JoeVR5
Jan 11, 2009 07:58 PM
jdray1967
Dec 3, 2008 08:21 PM
Mott
Mar 24, 2008 03:55 PM
corr04
Oct 31, 2006 10:02 AM
