Does anyone have an ECU pinout for a 94 LX?
Old Jan 9, 2014 | 09:10 PM
Where are you seeing another Wht/Red wire at Connector D?
Remember: Wht/Red is a wire with white color insulation and a red stripe.
Old Jan 9, 2014 | 09:17 PM
I am not sure what you are asking.
The O2 sensor has two circuits. The top one is the heater (voltage from B going to A11 on the picture above). All that does is heat the sensor, so the computer can read the signal faster. If voltage is missing at pin A11, then you get an error code for heater circuit malfunction.
The second circuit is the signal. There is a 5V reference voltage going to O2 sensor, Map, CYP, etc.. in the diagram above. Then the signal goes to D14. My guess for the dotted line and the connection to C (Ground) would mean this is a shielded wire?
Old Jan 9, 2014 | 09:25 PM
Originally Posted by kayweb
Or perhaps I didn't find it, since there are two white and red pins on D. Do you know what the other one is for?
Okay, found the other Wht/Red.
As stated previously, the heated oxygen sensor (HO2S) input should be a Wht/Red wire to pin D14.
Another Wht/Red wire, which is at pin D9, is for the alternator FR signal.
Attached Thumbnails Does anyone have an ECU pinout for a 94 LX?-22p-connector.jpg
Old Jan 9, 2014 | 09:34 PM
I don't know what source this diagram you posted is from. However pin A11 is a red wire for EGR control solenoid valve control at ECM Connector A, not related to the heated oxygen sensor.
Old Jan 9, 2014 | 09:38 PM
I will only temporarily posted these attached images, to allow you to see. However, after you've seen them, I will delete them.
Old Jan 10, 2014 | 02:28 AM
kayweb's Avatar
I was looking for a P0A wiring diagram and that's the only one i could find. Either way, I found the O2 sensor signal, wired the circuit however I think I may have crossed a wire somewhere because it's measuring voltage from the battery/alternator instead of the o2. Granted, the O2 sensor only puts out about a volt at full rich, but still, something weird is going on. Looks cool, though! Hopefully I'll have it figured out relatively soon. Secondary question: by unplugging my ecu, did i just reset it?
Old Jan 10, 2014 | 04:06 AM
  #17
holmesnmanny's Avatar
On any obd1 honda the pinout is the same with the exception of the 94-95 accords...on them pins A6 and A11 are backwards
Old Jan 10, 2014 | 05:26 AM
  #18
The wht/red wire at D9 is for the alternator field regulating signal.
If you disconnected the ECU, it will reset.
Old Jan 10, 2014 | 08:21 AM
  #19
Roader's Avatar
I'm building an AFR meter using the factory narrowband sensor. red is lean, green is stoich, yellow is rich.
Any chance of doing a youtube video and posting a link here after you get it working? Any plans to go from breadboard to a permanent circuit?
More ECU pinout diagrams: innovatemotorsports(dot)com/resources/ecu_pinout(dot)php
Old Jan 10, 2014 | 01:48 PM
  #20
CD5Accord's Avatar
That diagram came directly from the 94-95 OBD1 Honda shop manual... That is an image that I posted on Honda Tech a few years back.
Also remember that the WHT/RED signal wire from the O2 sensor is shielded as indicated by the dotted line running along side of it in that ECU pin out diagram. D14 is on the bottom row of pins just to the right of the connector center, while D9 is on the top row and to the left.
Just to clarify something as well;
90-95 OBD1 ECU pins are numbered
1 3 5 7 etc etc
2 4 6 8 etc etc
96+ OBD2a and OBD2b ECUs are
1 2 3 4 etc etc
11 12 13 14 etc etc
Also they are portrayed as if looking at the back of the connector going into the ECU.
