does brake idiot light mean bad rotors?
Old Feb 27, 2008 | 07:53 PM
lfbs01
Default does brake idiot light mean bad rotors?
I checked the brake fluid and its good. I unpluged the wires to the brake fluid cap and still the brake light comes on when I put the car in gear. It came on a few weeks ago and has been on ever since when the car is not in park or neutral.The parking brake works fine and itsnot on.Is there a chance that bad rotors will set off the light? I just changed the brake pads because I thought that might be the problem but no help.
Old Feb 27, 2008 | 08:45 PM
gomarlins3's Avatar
Default RE: does brake idiot light mean bad rotors?
Possible a bad switch on the e-brake lever? Sounds like you already checked all the options I was going to say.
Old Feb 28, 2008 | 02:43 AM
what year/model of accord do you have?
Old Feb 28, 2008 | 07:14 AM
BlkCurrantKord's Avatar
Betcha one of the brake lamp bulbs is blown. Have someone press on the brakes as you stand at the back of the car.
Old Feb 28, 2008 | 08:20 AM
00AccordLX5spd's Avatar
Registered User
If no brake lamp is out, it could be one of the following: A bad master cylinder cap, a faulty float (attached to MC cap), or the filter inside the master cylinder (has been upgraded by Honda.)
Type in "brake light" in the search engine and you should find a few threads on this.
Old Feb 28, 2008 | 11:52 AM
ORIGINAL: BlkCurrantKord
Don't confuse the different warning lamps. If it's got anything to do with brake light bulbs, the warning lamp will say "Brake Lamp" (not just 'brake').
Old Feb 28, 2008 | 01:16 PM
lfbs01
Its not the "brake lamp" light its the one that says brake. So its not the taillights.
Old Feb 28, 2008 | 01:17 PM
lfbs01
1994 lx coupe
Old Feb 28, 2008 | 02:44 PM
Registered User
FYI: the brake light will not come on if your rotors or pads are worn out. There is no sensor on them to cause the light to come on that I am aware of.
Old Feb 28, 2008 | 04:26 PM
brayner's Avatar
I'm kinda new to Hondas, but I thought the basic brake light indicated a differential in the hydraulic system (or hand brake)??
