Dome Light intermittently coming on
Old May 28, 2019 | 08:51 PM
Shawn Walkey's Avatar
Default Dome Light intermittently coming on
I have a 2007 Honda Accord EX. My map lights/dome lights intermittently come on when I go over a bump, turn right or lean my leg against the driver door while driving. is there a switch on the door that is possibly going bad or has a loose connection?
Old May 29, 2019 | 07:33 AM
Does the "door-open" warning come on at the same time?
Each door has it's switch - a little plunger in the door-frame that gets pushed in when the door closes. Check those are OK. Each one connects its wire to ground when the door is open. So you can also look for the wiring to be making a short to ground somewhere near where you lean your leg against the door.
Old May 30, 2019 | 12:21 AM
justme71's Avatar
Could also be the switch screws are loose?
MSC71
Nov 23, 2019 05:28 PM
bdrumm
Oct 30, 2012 10:46 AM
N1Accord
Mar 24, 2011 11:27 AM
mbaron
Apr 8, 2006 02:23 PM
