Dome light Problems
Old Dec 24, 2008 | 01:32 PM
cjdm98's Avatar
Default Dome light Problems
Having a problem with my dome light and map light,i was trying to install my ebay led lights,they didn't fit correctly,so i tried to force them in there,..long story short...saw a spark,put my old bulb back in,and now my dome and map lights will not turn on,i already checked fuses,and etc..
Any suggestions?
Old Dec 24, 2008 | 02:10 PM
finch13's Avatar
Default RE: Dome light Problems
Noob. No clue what to tell ya...
Old Dec 24, 2008 | 04:12 PM
cjdm98's Avatar
Ugh..this is pissing me off.
Old Dec 29, 2008 | 04:41 PM
cjdm98's Avatar
Got the dome light working now, But....The light doesnt dim out when i have it on the "door" setting..Normally it dims out then off.Now it stays on...Any Ideas?
Old Dec 29, 2008 | 09:48 PM
finch13's Avatar
Your dome dims out? Mine just turns on and off with the door... I guess I fail and now you fail too.
Old Dec 29, 2008 | 10:01 PM
cjdm98's Avatar
It basically turns off,but now it stays on,even when all doors all closed.[:@]
Old Nov 29, 2011 | 01:26 AM
Canuckle04's Avatar
I know it's an old thread but I've had the same issue.
Doors closed but dome light stays on when in 'middle' position?
Any suggestions?
Thanks;
Old Nov 30, 2011 | 11:50 AM
cutlass327's Avatar
Was this after the conversion to LED? If so, the LED doesn't draw enough power to used the stored energy in the capacitor that causes the fade-out, if they have it designed so that is dependent on the bulb. Otherwise, you may have toasted the transistor the controls the dimming.
LEDs are nice in that they are colorful and cool, but not every incandescent bulb can be replaced by them properly. LEDs don't fade/dim, they are usually on/off.
bdrumm
Oct 30, 2012 10:46 AM
milescwright
May 23, 2010 09:46 AM
dan_o_89_rs
Jan 25, 2008 10:29 AM
eckhart
May 8, 2006 01:05 PM
