Door Ajar Chime Whenever I Brake
Old Apr 27, 2009 | 02:07 PM
89hondaaccord
Default Door Ajar Chime Whenever I Brake
I have an 89 honda accord lxi. It's hitting about 90 degrees where I live and in this weather it seems that the door ajar chime goes off every time I brake. Once it gets cooler it stops, or if I accelerate. I can hear something move in the door jamb whenever I brake, but it seems to be within the frame of the car, not just the rubber door jamb moving. If I could just disable the beep by pulling a fuse or disconnecting a wire I would but doesn't seem to be a specific wire or fuse for the door ajar chime. Any ideas?
Old Apr 27, 2009 | 03:23 PM
Look at the wiring for the door switch. That probably operates by closing a ground connection when the door is open. Look for some worn wiring that touches ground when the wire moves one way or another.
mmukh001
Nov 20, 2012 10:36 AM
drummer1279
Jul 30, 2009 11:26 AM
schmo1
Apr 12, 2008 05:25 PM
eckhart
May 8, 2006 01:05 PM
