Door Locking Mechanism
Old Oct 25, 2010 | 09:04 PM
seuss's Avatar
Default Door Locking Mechanism
On my 2003 Honda Accord DX, I damaged the latch that locks the door to the car body (a photo is attached). All I did is push it down a bit, and now it is locked down, and the door does not shut or lock anymore. This is a manual lock system (not central lock). Is there a way to release the latch back to its normal position?
Old Oct 25, 2010 | 09:11 PM
Have you tried using your key in the door cylinder to unlock it?
Old Oct 25, 2010 | 10:25 PM
seuss's Avatar
The key does not work which is how I got in this mess in the first place. I was trying to fix the lock.
Old Oct 25, 2010 | 11:11 PM
You may have to remove the door panel to check it out. One of the latch rods may have gotten detached or something. Usually when the specific rod is pulled up, the latch releases. Many times it is better to just replace the latch, because you don't want it to malfunction and can't open the door either.
Old Oct 26, 2010 | 10:21 AM
hondadude's Avatar
have you tried pulling out on the latch hook while working the latch handle?
Old Oct 26, 2010 | 10:54 AM
seuss's Avatar
Thank you two-eyed technician!! it unlocked as easily as it had locked.
Old Nov 20, 2011 | 09:21 AM
andrewsmith's Avatar
Had the same problem this morning - thanks to your post I'm good to go! Thanks so much!!!
MessAround
Aug 30, 2017 10:05 AM
craigeraccord
Mar 12, 2015 04:50 PM
stonesfan
Jul 31, 2012 11:33 AM
crvone
Sep 18, 2007 03:48 AM
kpearson10
Aug 23, 2005 02:34 PM
