Door Locks Not Working
Old Nov 16, 2013 | 07:00 PM
camman's Avatar
Default Door Locks Not Working
I recently bought a 99 accord 2dr, the only thing wrong with it is the door locks, you can lock/unlock them manually with key or pushing them down, but with the button or key fob nothing happens, except a click, and the security system don't arm unless i use the key. if its an actuator, can i buy them together or are the door specific?
Old Nov 20, 2013 | 09:41 AM
Dr. Drivability's Avatar
My diagram could be wrong, but have you checked the no. 12 fuse in the passenger side fuse box yet? Also, is this an EX or LX trim level?
Old Nov 20, 2013 | 01:15 PM
Yes, check the No. 12 (20A) fuse in the passenger side fuse box.
The actuators are door specific. However, before replacing them, I would:
  • check the fuse
  • test the actuator motors by applying direct power and ground to them
  • test the driver's door multiplex control unit.
wglewgle
Dec 14, 2013 10:11 AM
paulson524
Aug 10, 2013 10:13 AM
paksen
May 18, 2012 08:07 PM
jdarrah66
Feb 22, 2012 06:09 PM
Antarctica
Oct 5, 2010 08:33 PM
