Dreaded P1167 Code 01 Accord 2.3L No Ground
Old Dec 24, 2017 | 07:13 AM
c4yourself2's Avatar
Default Dreaded P1167 Code 01 Accord 2.3L No Ground
Hello All,
My son has a 01 Accord showing P1167 with a new O2 sensor installed, so I checked the connector with voltmeter and I have 12 volts but no ground signal at the connector to the #1 O2 sensor, any suggestions? I need to ohm the connector pin with the wire itself which I have not done yet. Also pulled #6 fuse at DS door and it's good. I could use a wiring diagram of the PCM and sensors. I did a search before posting, not sure were the ground wire goes to one diagram shows it going to a common ground another thread talks about it going to the PCM. I believe I found what I needed to trace the ground wire. Connector "C" terminal 18 Green/Black wire.
Update: https://www.hondaaccordforum.com/for...diagram-61059/
Chuck
Old Dec 24, 2017 | 12:46 PM
Update - The black/white wire at the O2 sensor and the green/white wire at the PCM connector "C" 18 do not have continuity. Do I run a new wire from C18 through the firewall and out to the black/white wire?
Chuck
Old Dec 25, 2017 | 08:43 AM
Default From the Manual
From the shop manual...hopefully this helps someone in the future....
Chuck
Cinawina
Nov 5, 2024 08:35 PM
akola
Oct 8, 2018 05:07 PM
voy82
Mar 5, 2017 08:01 PM
cuda6pak
Oct 5, 2013 09:38 AM
DisplacedMic
Jun 15, 2011 08:25 PM
