Driver side electric window
Old Nov 21, 2007 | 09:18 PM
pjlooby
Default Driver side electric window
My daughter's 1993 Accord EX driver side master window switch had died. Her window is down and I was wondering if there is any way get it up until I get a new switch and replace it. Can I take the panel off and somehow jump the motor so it will go up? Really need advice. Thanks
Old Nov 21, 2007 | 09:37 PM
hondadude's Avatar
Default RE: Driver side electric window
Sure, when the panel is off you can peel back the plastic liner and find the 2 pin connector between the switch and the motor, then use a spare battery to jumper power to the motor.
Old Nov 21, 2007 | 09:44 PM
pjlooby
Thanks. I'v got to try it tomorrow after work. I hope its not a real pain to do. I'v never worked on this car before.
Old Dec 1, 2007 | 12:08 PM
HondatechAV6's Avatar
are you sure it's the switch and not the motor? if the motor is shot it won't budge. you'll have to unbolt the window from the motor and tap the window in the up position.
did you get a change to check it out?
gary85_
Jun 7, 2014 08:18 PM
jza240sx
Apr 30, 2013 04:14 PM
ndp
Jun 7, 2009 05:23 PM
19accord92
Apr 10, 2006 03:52 PM
