Driver Side Headlights arent working.....
Old Mar 9, 2007 | 07:45 PM
Guest
Default Driver Side Headlights arent working.....
Alright, I've just recently realized that my driver's side Headlight isn't working... 94 Accord EX.. Neither the low or high is working... I've checked the fuse box and the fuse is good... I checked a working one with the Right and Left side Headlight spots.... The right side works but not the left... I've checked the wiring by the headlights and there is no sign of wiring problems... Any solutions???
Old Mar 9, 2007 | 08:08 PM
sir_nasty's Avatar
Default RE: Driver Side Headlights arent working.....
first off I'd pull the connectors/wiring off the headlights and see if there is power running to it, if there is no power to the wiring then we've got to start tracing back, you said the fuses are fine, there is a chance that it's the combo switch if there isn't any power.... park in front of a wall and turn the headlights on, jiggle/move the combo switch around and see if that left side kicks on, if it does or if it flashes then it's probably a bad conneciton in your combination switch.... those are the easiest tests to start with.... let us know the results, from there you may have to start tracing wires and testing a bit more
jza240sx
Apr 30, 2013 04:14 PM
accord3000
Dec 21, 2011 09:02 AM
newtohondas
Sep 18, 2006 07:40 PM
thunder_x
Jul 6, 2006 02:14 AM
