Driver side window problem
Old Jun 2, 2011 | 10:32 PM
chaddibanyan's Avatar
Unhappy Driver side window problem
Since Past few days, when I roll up (I mean press the button) the driver side window to close it, the glass pane takes some part top rubber lining along with it inside....and it looks awful from outside....I will attach a pic soon...please suggest a solution...will I need to change the rubber lining completely ?
Old Jun 3, 2011 | 08:45 AM
draser's Avatar
Out of alignment condition - Check if the top rubber channel molding has become loose in the door top frame, you should see it when window's down. Also, is the glass loose? - take it .5 way down and grab the top and check. Make sure the glass is in the side channels as well. If the damage is already done to the top rubber you may need to replace.
Old Jun 3, 2011 | 11:52 AM
jgw's Avatar
jgw
A common problem for Honda. It is likely to be the runners.
At the bottom of the glass there is a couple of round plastics wheels that go along the runners on the regulator as window goes up and down. Aftertime the plastics starts to split and the wheel slips on the runner.
Eventually the window will drop on one side when the plastics has totally gone and it will fall of the runner.
Take the door panel off and have a look at the runner.
On my accord the wheels were a part of the window and so a new window was needed. You may be lucky and be able to remove the wheels from the window and take a trip to the scrapyard.
jza240sx
Apr 30, 2013 04:14 PM
Michael Bomes
Sep 9, 2012 03:12 PM
RobJL94
Aug 14, 2012 06:56 AM
elstongunnn
Oct 21, 2009 10:42 PM
19accord92
Apr 10, 2006 03:52 PM
