Drivers Side Door Lock not working
Old Apr 22, 2019 | 07:57 AM
ACARRANO's Avatar
Default Drivers Side Door Lock not working
Drivers Side Door lock on 2013 Accord does not work with Keyfob
I have a strange issue - the Drivers side lock on my 2013 accord no longer works.
- If I click unlock all others doors unlock but not the Drivers side.
- If I manually Lock the car I have to Use the key to enter.
- If I click the unlock button, all other doors work but not the drivers side. Same with manually hitting Lock.
I did check the fuses (I believe they were #s 19 and 21) they seem sound.
Any suggestions?
Thank you.
Old Apr 22, 2019 | 08:38 AM
First, I'm going to move this to General Tech where more people will be seeing it.
2-door or 4-door?
Probably you have to remove the inner door panel to have a look around. I'm not familiar with the 2013 but here's some initial questions.
Can you hear the actuator making any sound in the drivers door when you use the remote? If so, then look for a disconnected mechanism from the actuator to the actual latch.
No sound? Electrical issues including maybe flaky wiring connections or a non-functioning actuator.
Old Apr 22, 2019 | 08:51 AM
ACARRANO's Avatar
Thank you.
Its a 4 door.
I hear locking sounds across all three others doors, nothing from the drivers door (whether I click the FOB or I hit the lock button internally).
I was debating on purchases an actuator, but not sure how difficult to replace (my brother in law is very handy).
DravenX
Sep 23, 2013 10:36 PM
Doublel
Mar 11, 2013 07:57 AM
Motman Idaho
Mar 22, 2012 10:20 PM
noobkupo
Mar 3, 2011 07:45 AM
bvkiran
Mar 3, 2010 10:23 AM
