driver's side window
Old May 11, 2010 | 10:39 AM
earl's Avatar
Default driver's side window
my drivers side window will not close. I have checked the fuse and its OK. There seems to be draw on the battery when I move the switch.
Old May 11, 2010 | 10:40 AM
earl's Avatar
Sorry, there seems to be no draw on the battery.
Old May 11, 2010 | 11:15 AM
(I combined your separate posts into the same thread.)
Old May 11, 2010 | 01:32 PM
earl's Avatar
Default update
I have the door disassebled to the point where the motor and operator are on the outside. I plugged the control and motor back into each other. When I used the switch on the control panel, the motor will only run in the direction which causes the window to go up. Trying to put the window up does not work at all. Is this a swich problem or a motor problem. Please can anyone help me
Earl
Old May 11, 2010 | 02:19 PM
On the electrical connector going to the window motor, there are 2 wires that you will have to probe, the red/yel and the red/blu. You will need a volt meter to do this test.
For the window going down, red/blu will have 12V and red/yel will have continuity to ground.
For window up, red/yel will have the 12V and red/blu will have continuity to ground.
Old May 11, 2010 | 09:52 PM
earl's Avatar
thank you
Old May 16, 2010 | 02:40 PM
Wicked Pete's Avatar
What would be the OHM rating of the motor (1995), and how do you read it?
jza240sx
Apr 30, 2013 04:14 PM
iimzii85
Nov 1, 2010 01:16 PM
ndp
Jun 7, 2009 05:23 PM
19accord92
Apr 10, 2006 03:52 PM
