driver's side window
I have the door disassebled to the point where the motor and operator are on the outside. I plugged the control and motor back into each other. When I used the switch on the control panel, the motor will only run in the direction which causes the window to go up. Trying to put the window up does not work at all. Is this a swich problem or a motor problem. Please can anyone help me
Earl
Earl
On the electrical connector going to the window motor, there are 2 wires that you will have to probe, the red/yel and the red/blu. You will need a volt meter to do this test.
For the window going down, red/blu will have 12V and red/yel will have continuity to ground.
For window up, red/yel will have the 12V and red/blu will have continuity to ground.
jza240sx
Apr 30, 2013 04:14 PM
iimzii85
Nov 1, 2010 01:16 PM
jblackwe1969
DIY Answers.
Jul 8, 2010 12:04 PM
19accord92
Apr 10, 2006 03:52 PM
