Driving Woes
Old Sep 12, 2011 | 02:26 PM
RIPauntM's Honda's Avatar
Question Driving Woes
I have a 2003 Homda Accord...... driving just fine today, car started jumping...... won't go over 2500rpm. Had it towed home...... HELP!!! Any idea what it could be!
Old Sep 12, 2011 | 04:15 PM
Lightbulb 1st Let's Put You In The Right Forum...
Here You Are..The right forum... dbl click..real picture not a fake...
Old Sep 12, 2011 | 04:30 PM
You may have had an engine misfire and the computer kept the car in a limp-mode. Most likely the Check Engine Light was on. If you get the car scanned for trouble codes, then that could try to help narrow down what may be the cause of the problem. Without a trouble code and/or more information, there not too much we can tell you. If you do happen to be able to retrieve the trouble code(s) via someone with a OBD-II reader/scanner, then post the code and whether your Accord is 4 cylinder or 6.
shiveringmonkey
Mar 10, 2010 11:04 PM
tordoff
Jan 13, 2009 11:53 PM
Blenton
Jun 20, 2008 06:54 PM
richomundo
Feb 26, 2007 09:11 PM
Brendo613
Feb 23, 2006 07:26 PM
