ECU Ground
Old Dec 4, 2012 | 08:01 AM
RobinsonRicer's Avatar
Default ECU Ground
You can see my other thread for reference but I'm wonder, when I took out the ECU to put in a chipped obd1 ECU I put the old one back in cuz I was having issues with the new one but did not screw the nuts in all the way expecting to take it back out soon. Is that metal bracket holding the ECU to the chassis grounding the ECU? Could that be my issue and is why I'm having intermittent performance problems?
Old Dec 4, 2012 | 09:28 AM
The ground wire for the ECU is attached to the intake manifold, see attached pic.
Old Dec 4, 2012 | 09:39 AM
Yeah, I'm familiar with that ground to ground the ECU. Would the ECU not being completely secured to the chassis in the cabin cause an intermittent issue?
...I have some ideas, im gonna do a continuity test as well. I'm just wondering if that also grounds the ecu
Old Dec 4, 2012 | 12:55 PM
Roader's Avatar
Not in my experience. For a week or so my ECU was just lying on the floor not bolted in and I had no problems with either CELs or performance. A lot (most?) of the inputs and outputs of the ECU are in the five-volt range. With those low voltages I don't think Honda would rely on a case ground.
Old Dec 5, 2012 | 11:36 PM
Ok. That makes sense. Thanks.
Old Dec 6, 2012 | 09:08 AM
Dr. Drivability's Avatar
all grounds are provided through the harness connector for the ECM
Old Dec 6, 2012 | 04:57 PM
It appears that not all grounds were sufficient with the age of the car. the grounding kit has provided my car with a more torque, brighter lights, and a reduction in the intermittent quirks. Perhaps g101 was grounded to the manifold but from there to the engine head and block it was not grounding to the chasis correctly until I put the extra cables in.
Dieskyver
Dec 8, 2014 06:30 PM
live2rice
Sep 20, 2012 02:26 PM
F23AccordLX
Feb 24, 2006 07:48 AM
theycallmerickjames
Oct 10, 2005 03:00 PM
