ECU removal?
Old Dec 12, 2022 | 04:57 PM
Danabryant1979's Avatar
Question ECU removal?
Is there a guide or some place that shows how to remove the ecu on a 2013 accord 2.4?
Old Dec 12, 2022 | 10:17 PM
The shop manual is probably your best bet for a guide. I'm pretty sure the PCM is in the engine bay on the driver's side of the bay towards the windshield. Look at PCMs on Ebay to know what the PCM looks like.
It should be pretty obvious how to remove it. Disconnect the battery. The disconnect unbolt any items blocking you from access in the PCM. You may have to remove the PCM with the bracket, the remove the PCM from the bracket. You probably have to unplug the connectors before removing the bracket.
Mario Locatelli
Mar 8, 2014 10:17 PM
Infinite1
Aug 27, 2012 11:32 AM
XxBladesxX
May 4, 2012 06:13 PM
Adie
May 14, 2006 09:17 PM
accordinprogress
Dec 6, 2005 09:41 PM
