95 accord ex coupe F22b1 Abs module/accumulator wont bleed
Old Dec 13, 2022 | 12:25 AM
AftermarketAccord's Avatar
Default 95 accord ex coupe F22b1 Abs module/accumulator wont bleed
Hello guys I’m trying to bleed my abs module on my 95 accord, I back probed the abs pump wire an set up a test wire on my battery, when I touch the test wire to the pump wire it wines like it should, so as I manually pump it i then open the bleeder screw an get nothing no fluid or pressure just noise from the pump, I also have a code 1 abs on my dash. abs light always turns on after pump wines once started. I also have half a brake pedal meaning I think only the front brakes are engaging mostly. I bought a prop valve just in case because I don’t want another crappy abs module if needed. I also notice slight wetness around the module, around the lines connecting an revisor.
Tompkinswest
Feb 7, 2019 01:14 PM
blumule
Mar 14, 2013 03:39 PM
rocketrooney
Apr 23, 2012 10:28 AM
grabber
Oct 19, 2006 10:40 PM
F23AccordLX
Mar 27, 2006 11:50 PM
