EGR help??
Old Jul 6, 2013 | 12:17 AM
camman's Avatar
Question EGR help??
I have a 97 accord SE 2.2L non vtec AT, i got trouble code EGR insufficient flow, i replaced the whole EGR valve and Cleaned out the EGR ports. today i got code 12 EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor, and don't know what to do, i figured i should start here before i take it somewhere.
Old Jul 6, 2013 | 01:16 AM
kayweb's Avatar
I think I had the same problem, and it was because the egr solenoid (right hand side of the bay, next to the abs pump or whatever it is) was unplugged.
Old Jul 6, 2013 | 07:44 AM
Did your replacement EGR valve have an electrical connector for the lift sensor harness to connect? If yes, I would suspect a defective part. The EGR valve rarely fails, so you might try re-installing old EGR valve.
You can check the EGR valve for function by sucking on actuator diaphragm and verifying valve movement. If you have a hand vacuum pump it may be "cleaner".
Similarly you can blow and verify it is sealing when normally closed.
Old Jul 6, 2013 | 02:01 PM
camman's Avatar
i didnt install the new egr valve, maybe if i took it off and made sure the connections were good, where does the lift sensor harness connect at?
Old Jul 7, 2013 | 06:18 AM
The "lift" is on the actual EGR valve - but as suggested it could be something else. Meaning the ecu is looking for a "lift" reading from the egr valve at certain times - if a solenoid is not working and never sending vac to the valve....well you get no lift and the code will set.
Start with the valve - if that checks out there are more things we can test.
mamtsberg
Mar 17, 2010 09:15 PM
olgirlkeepsrunnin
Jan 31, 2010 02:37 PM
RJLhonda
Sep 9, 2008 01:05 AM
Resatimm
Jan 5, 2007 02:03 AM
HondagalGA
Jun 25, 2006 04:18 PM
