EGR Valve Code
Old Mar 1, 2010 | 10:26 AM
Richouse's Avatar
Default EGR Valve Code
I have a 2002 Accord LX, 3 litre V6, auto Trans. Has 120K + miles. Check engine light came on and the code related to the EGR Valve. So I changed it. As you prob. realize (since im here) it didn't fix the problem, check engine light came back on and still getting bad gas mileage. I have since taken the valve back off and sprayed carb cleaner in the ports to clean out the carbon. The light still came back on. What else can I do to fix this???
I appreciate any and all suggestions.
Thanks,
Richard
Old Mar 1, 2010 | 11:47 AM
deserthonda's Avatar
those have issues with the egr ports being plugged ,,,,,most likely that might be the issue , if so you need to remove the planum and clean the ports , ,. post the code here ,,
Old Mar 1, 2010 | 03:35 PM
Richouse's Avatar
Ok, I found the directions to clean the egr ports for a 94 accord in the DIY section. Are these instructions valid for a 2002? I don't have the actual code to post as I am out of town right now. But if I remember correctly it is the egr flow code...
Thanks...
Old Mar 1, 2010 | 05:42 PM
The procedure on a V6 is different. Google 99-085 service bulletin
The first link will give you the instructions on what to do.
Old Mar 2, 2010 | 08:38 AM
Richouse's Avatar
Found the instructions Thanks. It says it applies to '98 - '01 models I just want to make sure this fix will work on my '02 I don't know if there were any significant changes. My next question is where do I get the kit with the special drill bit and EGR pipe? Can I go to my local Auto Zone or do I have to get it at the Honda dealer? Will the dealer even sell me this kit???
Thanks for all the help!!!!!!
Old Mar 2, 2010 | 05:48 PM
The 02 setup should be identical to the 98-01, because they are the same generation accord.
The kit would be sold at the honda dealership, and they will sell it to you. I don't know if the parts stores sell them.
Old Mar 2, 2010 | 11:33 PM
Old Mar 4, 2010 | 08:59 PM
Richouse's Avatar
Thanks for all the good info. I feel confident that I will be able to fix the problem now.
Now all I need is some instructions on how to change the timing belt while I have the engine all pulled apart.
Thanks,
Richard
Old Mar 5, 2010 | 11:13 AM
hondadude's Avatar
The timing belt is a completely different story, and there would be no work duplicated from the EGR port cleaning.
bjr001
Jul 14, 2013 07:12 PM
NZXTInerTia
Jul 20, 2012 03:06 AM
archangel_1988
Dec 13, 2011 11:43 PM
olgirlkeepsrunnin
Jan 31, 2010 02:37 PM
RJLhonda
Sep 9, 2008 01:05 AM
