Electrical/Charging system trouble
Old Mar 28, 2013 | 12:15 AM
Sabreflier's Avatar
Default Electrical/Charging system trouble
1990 Honda Accord EX
For the last couple of Months my headlights would go dim and then bright while driving. The other day my radio turned off, all my dash gauges went to zero, but the car stayed running. This happened a couple of times. I drove my truck for the next 2 days. When I tried to start the Honda it would not turn over.
I jumpstarted the car and while running cold the voltage was 14 V. After about 10 minutes the car started idling rough and voltage was 12.3 V and dropping.
I installed a new battery and had the same results 12.3 V with rough idle.
I took out the alternator and original battery and took them to AutoZone for testing. They said the alternator was good and the battery was bad. This doesn't make sense because I have the same result with the known good battery.
Any help would be greatly appreciated. I've read about an ELD issue. Would that cause these symptoms?
Old Mar 28, 2013 | 08:08 PM
Just me but it sounds like a bad alt?
Yes, you take it off the car and test it but they test it for all of one minute and at the same time you say it is fine in the car for 10 min.
Were your readings from the charge post on the alt or just at the battery?
I'm thinking a new volt reg in the alt and life will be good......but more TESTING is needed.
Old Apr 7, 2013 | 09:47 AM
Jay O 69's Avatar
Default voltage drops from 14:5 too under or around 12 volts
Hello all Im having a problem with voltage drop I put on a new alternator Im Still having the same problem no change it drops to 12 Volta without headlights on If I turn headlights on voltage comes back to normal . Any suggestions ?
schoust
Mar 1, 2013 06:16 PM
mb28
Aug 19, 2011 08:26 PM
my97hondase4banger
May 28, 2010 05:33 PM
mjhenks
Apr 21, 2008 09:35 AM
gfe9
Mar 20, 2008 06:51 PM
