Electrical (I Think) Starting Problems 2005 Honda Accord V6 3.0L
Old Sep 8, 2018 | 12:58 PM
LHILL's Avatar
Default Electrical (I Think) Starting Problems 2005 Honda Accord V6 3.0L
I am having an issue starting my car (2005 Honda Accord V6 3.0L). What I thought it was.. can still be, or it may be something else. My key turns over, the lights come on, it beeps. It does everything it needs to do except turn over and start. Just recently this happened and I thought it was my battery...nope. Then I thought the spark plugs.....nope. I haved the starter and alternator checked. The next thing I could think of was the ignition switch and lock cylinder...got that changed...the car was good for about a week...starting like always. And now it's back to doing the same thing. No Crank No Start. Please HELLLLLLLP ME. Where do I look next? I love my car!
Thanks
miles 289,00
Old Sep 8, 2018 | 01:03 PM
Seanjordan20's Avatar
Starter going bad. Change it out. To test it out when it's not starting hit the starter with a hammer. If it starts then replace it
Old Sep 8, 2018 | 02:28 PM
First tell us what you mean when you say it doesn't "turn over & start". To most people that means the starter isn't spinning the engine. If that's the case, do what Sean says.
Some people use that phrase to mean the starter spins the engine OK but the engine doesn't fire up & run. In that case, tapping the starter won't help. Just let us know...
Old Sep 8, 2018 | 02:48 PM
JimBlake is correct
Old Sep 9, 2018 | 09:05 AM
LHILL's Avatar
The engine will not fire up. I have tapped with a hammer and had the starter checked...
Old Sep 9, 2018 | 09:15 AM
So you are having a crank but no start issue. I say replace the starter and you will be fine. I don't know how you had the starter checked but if they didn't remove it how else did they check it
Old Sep 9, 2018 | 09:29 AM
LHILL's Avatar
No the engine is doing a one click sound (not the starter bad click sound)...but other than that nothing from the engine. I believe it's a no crank no start
Old Sep 9, 2018 | 09:55 AM
You have 2 choices to choose from. Since you said you changed your ignition switch and had the battery/alternator checked. You're saying you get one click when trying to start.
EFI relay
Starter
Your EFI relay should be clicking multiple times if its bad so I'm not leaning that way but you can try it. Napa part ECH AR6229 or Standard Motors RY737 (Advance Auto) depending on where you shop
Your starter you say was checked. Your starter still works as it's going bad. This is where I'm putting my bet at. You say you have one click when trying to start. that is the fuel pump relay working. You have no other sound which means the starter is bad.
Old Sep 9, 2018 | 10:18 AM
LHILL's Avatar
EFI relay
Starter
I'm going to try both. I thought it could be a relay as well. My starter is just a year old but I'll just take it out anyway. And I will check it myself. Thank you. I will keep you posted. Thank you so much
Old Sep 9, 2018 | 11:50 AM
If your starter is a year old it should be under warranty if you bought it from an auto shop. I know advance auto gives lifetime on their remans. Try to warranty the starter to save money. The relay should be around $40
If you don't know where the EFI relay is it's just above the fuse box inside. Remove the whole trim where the fuse box is. Above the fuses you will see 2 rows of relays. The top row 2nd from the left (middle) is where it sits. It should be brown in color.
