Electrical (I Think) Starting Problems 2005 Honda Accord V6 3.0L
Old Sep 9, 2018 | 01:58 PM
The Toecutter's Avatar
Dead battery?
Old Sep 9, 2018 | 02:00 PM
Seanjordan20's Avatar
The OP says he had the battery and alternator checked.
Old Sep 9, 2018 | 04:20 PM
If you are turning the key to start the engine and the starter does not rotate the engine, then that is a no-crank, no-start. If the starter rotates the engine, but the engine will not run on its own (when you typically release the key), then that is a crank, no-start. Please verify what is happening on your car.
The testing you can try will depend on your answer above.
Old Sep 12, 2018 | 10:58 AM
LHILL's Avatar
So my car works now!!!! It was definitely the starter. Even after I had it checked several times. I pulled out myself and bench checked it. It was bad...thank you so much for making check that starter myself. I replaced it and it started right up. I have never had that happen before it normally clicks. THANK YOU SO MUCH FOR THE HELP
egchin4
Sep 9, 2018 09:09 AM
94 Accord EX
Nov 15, 2010 01:19 AM
swano586
Nov 18, 2009 09:02 PM
Smitty263
Feb 10, 2008 08:16 AM
YeuEmMaiMai
Aug 3, 2006 03:02 AM
