Engine code p1367
Old Sep 11, 2006 | 03:00 PM
SkyLand
Default Engine code p1367
Hello,
I have a 2000 Honda Accord EX V6 with a code p1367 (No Signal In TDC 2 Sensor Circuit). Is this a matter of just replacing the sensor and if so are there any illustrations or pics of where this is located? Thanks
Old Sep 11, 2006 | 07:24 PM
hondadude's Avatar
Default RE: Engine code p1367
Not the best picture ever seen, but it should help you
TDC sensor
Old Sep 11, 2006 | 10:35 PM
Chiovnidca's Avatar
ORIGINAL: SkyLand
Hello,
It could be a wiring problem.
Old Sep 12, 2006 | 05:12 AM
deserthonda's Avatar
Before you do anything,, chk for a lose connection or lose wire,, if ok,, clear the code and test drive the car ,, if lite comes back on, try these quick tests
unplug the connector for the TDC ,,,,,,ignition switch off..
where it snaps on, the top 2 wires are for the tdc 1 ,, the bottom 2 are for tdc 2 .. ( code p1367)
measure rsistance between the 2 wires,,,,,,,should be ,,1,850-2,450 ohms .. if out of specs replace the sensor
if within specs,,,,,,,,,chk for continuity to body ground on each wire .....if there is continuity,, replace the tdc sensor ..if no continuity we need to go to the PCM and troubleshoot it from there......
try what i suggested first and see what happens
Old Sep 12, 2006 | 03:22 PM
SkyLand
ORIGINAL: hondadude
TDC sensor
Thanks,
It showed me exactly where to look.
Old Sep 12, 2006 | 06:28 PM
SkyLand
ORIGINAL: deserthonda
I checked the ohms on both the top and the bottom pins. The top two didnt show any resistance but the bottom two did read. Could the top two actually be the #2?
Old Sep 14, 2006 | 11:07 PM
SkyLand
Well after testing the old cam sensor it seems to be bad so I have purchased a new one. Does anybody know where to go online or have pics from a factory service manual on changing this sensor? Thanks.
Old Oct 11, 2006 | 07:43 PM
SkyLand
Well after buying a new sensor and then really studying where it goes I decided to call in reinforcements. It wasnt something I wanted to attempt without a FSM or a little help. Removing the timing belt and one of the flywheels did not look too easy. Anyway the sensor is replaced and the Accord is back to running fine. Thanks for any help.
Robert Bean
Mar 12, 2012 10:23 AM
tingjunkie
Sep 17, 2010 06:37 PM
will'i'am
Sep 16, 2010 01:19 PM
Stener75
Jul 25, 2010 08:21 PM
madsteez
Jan 18, 2009 07:43 PM
