engine codes
Old Jul 25, 2012 | 01:06 AM
bluedemon's Avatar
Default engine codes
Hey guys my engine light went on today. When I first started the car(I haven't run it for a month because I was on vacation) it stuttered really bad and the engine light started to flash after about 30 seconds it cleared up and ran normal and the engine light stayed on without flashing. When I ran the codes I got code 65 and code 72.
I am pretty sure that that code 72 is my fuel injecter on cylinder 2. I had the engine light flash before and when I tapped the injecter it ran smooth again and the engine light went off
However I am not sure what code 65 means. Is it telling me I need a new rear o2 sensor?? Any help would be really appreciated! Thankyou!
Old Jul 25, 2012 | 02:03 AM
doctorbee's Avatar
you probably didn't use gas stabilizer and the gas fouled over your vacation. Put some Techron concentrate from wal-mart or any auto parts store into the gas tank. Drive it like a mad-man (Italian tune-up) and re-fill with high quality gas from chevron, shell, etc.
Old Jul 25, 2012 | 03:15 AM
bluedemon's Avatar
I was actually just thinking of replacing the injecter with a new one since it did happen before. Any ideas on code 65?
Old Jul 25, 2012 | 05:47 AM
Code 65 is Secondary O2 sensor heater circuit fault; open or short in the wiring, connector, sensor, or possibly ECM.
Disconnect O2 sensor and check resistance (10-40 ohms) of heater circuit (two identical colored wires usually gray). If open or shorted, replace O2 sensor. If OK, go to ECM connector w/ these wires, disconnect and check for open/short in wiring. If good, the ECM is likely root of fault.
Old Jul 25, 2012 | 07:01 AM
What year/model is this car?
Beginning in 2003 the sensor heaters have different resistances.
dacecil
Jun 21, 2012 06:27 PM
saad180
Jan 3, 2007 10:45 PM
hopkinted
Jan 2, 2007 04:11 PM
19Accord97
May 9, 2006 07:13 PM
B0BC0X
Dec 7, 2004 03:04 PM
