Emissions and Engine Problem Codes
Old May 8, 2006 | 11:37 PM
19Accord97
Default Emissions and Engine Problem Codes
Hey guys, I have a list of code errors and figured I would post them. Might take awhile but hopefully it will help someone out
Code --------- Problem -------------------- Solution
Code 0 - Faulty ECM - Check the ECM electrical connector. If no loose connectors are found, have the ECM diagnosed by a dealer service department.
Code 1 - Oxygen sensor - Check the oxygen sensor and circuit.
Code 3 - Manifold Absolute Pressure sensor - Check the MAP circuit and sensor.
Code 4 - Crankshaft Position Sensor - Check the CKP sensor and circuit.
Code 6 - Engine Coolant Temperature sensor - check the ECT sensor and circuit.
Code 7 - Throttle Position Sensor - Check the TP sensor and circuit.
Code 8 - Top Dead Center position sensor - Check the TDC sensor and circuit.
Code 9 - Cylinder Position sensor - Check the CYP sensor and circuit.
Okay, well I have a paper to write so I will update/finish this when I get the time!
Old May 9, 2006 | 01:47 AM
AgentofDarkness's Avatar
Default RE: Emissions and Engine Problem Codes
Good post, always test the circuit before you change the sensor. Nothing sucks more than getting a brand new sensor on there to find out it still doesn't work.
Old May 9, 2006 | 02:32 AM
deserthonda's Avatar
it is really nice of you to post the codes,, but if you go to GENERAL TECH HELP,,,,,,,,,there is a sticky there already ( honda obd trouble codes ) with a link with all the codes ....
Old May 9, 2006 | 02:38 AM
Desert...I'ts amazing that the stickys seem to never get used, they would save the members a lot of time if they would just use the search on this site..
Old May 9, 2006 | 11:07 AM
19Accord97
My bad! I didnt think to look there. You can delete this if you'd like
Old May 9, 2006 | 07:13 PM
lightshow's Avatar
i dont mind keeping it. your probably not the only person who didnt look in the general tech section
Maxtor
May 24, 2013 08:36 PM
rahulmunjal
Feb 27, 2012 12:10 PM
Fat Ryan
Oct 21, 2011 06:54 PM
codyheit
Feb 27, 2006 05:11 PM
evgentry
May 11, 2005 12:40 PM
