Engine Control Module (ECM) power relay 2004 V6 Accord
Old Jan 10, 2018 | 06:02 PM
sawtooth500's Avatar
Default Engine Control Module (ECM) power relay 2004 V6 Accord
I have a 4 door 2004 V6 Accord - I'm getting a P0685 code so I got a new Engine Control Module (ECM) power relay which I'm hoping will fix it. Before I start tearing stuff up though, anyone know where in the car this relay is physically located and about how hard it is to get to (ie how long it will take to change)? I'm finding lots of fuse diagrams on the internet but no where that shows where the relay is actually located... thanks!
Old Jan 10, 2018 | 07:59 PM
DTC P0685 can be caused by many other things other than the main relay 1.
See the attached Honda job aid PDF file.
Anyways, to answer your question, PGM-FI Main Relay 1 is located in the under-dash fuse box.
File Type: pdf
Old Jan 10, 2018 | 08:36 PM
Thanks! I know there could be other things causing that, but I figured I'd try the simple stuff first.
Old Jun 8, 2018 | 12:41 PM
Ralph Perez's Avatar
Did it fix the problem? Also what symptoms was the car having?
Old Jun 8, 2018 | 12:49 PM
Yeah it fixed it. Car seemed to shut off at random times.
Leonkowal
Mar 18, 2014 03:14 PM
metaluna
Feb 11, 2013 11:22 AM
Gordon
Oct 31, 2010 07:19 AM
Gordon
Oct 30, 2010 01:30 PM
pcpro215
Nov 16, 2009 03:01 PM
