engine cutting out on acceleration
I have a 93 EX. It has a manual transmission. If i rev it up without a load its fine. when i shift into 1st and start to move the engine cuts out, and its like there is no power. I push the pedal down till it is almost to the floor, then it kicks in at about full throttle. Then it does it for all the other gears. could it be the tps? thanks.
it does it when i first start the car whether its the first time of the day, or after going into a store or something and coming back out. it usually does it for a little while and works its self out. last night coming home on about a 60 mile trip it started doing it a couple miles before i got home. so it does it when the car is cold and hot. no tune up items, ill have to check on the stored codes. thanks
all contacts look good. including the rotor. I even cleaned everything up, and no change. It's an intermittent problem, it seems like it would be some kind of a sensor or switch or something. a distributor cap or something like that would be a constant problem, gradually getting worse. any other ideas?
wrencredle
May 3, 2013 07:20 PM
78gaw
Jan 20, 2010 09:45 AM
