Engine Died While Driving, Won't Start
Old Jul 1, 2012 | 08:53 PM
No spark with 12V going to the coil could be the igniter or the coil.
You can try some resistance tests on the coil itself, but a coil can test good, but still not work properly.
I would still check for codes. It takes a few minutes.
Old Jul 1, 2012 | 09:01 PM
Silver6gen's Avatar
I've not gotten a single code other than P0420 cat inefficiency during my issues. I have not had that code since i replaced my coil (which had a burn mark on the back)
Old Jul 1, 2012 | 10:06 PM
iStagl's Avatar
Originally Posted by Silver6gen
or the ignition control module (igniter) I'd think the igniter might be the problem here.
Alright, I'll give that a shot. But even with nothing coming out of the coil?
Old Jul 1, 2012 | 10:17 PM
iStagl's Avatar
How do I test for codes? I believe my car is OBD1, but I don't know how to check the codes with that sort of system.
Oh I don't have an engine light on either. It turns off after about 2 seconds.
Old Jul 1, 2012 | 10:19 PM
The igniter turn on/off the coil to generate spark. So a good coil would still give out no spark.
Go to the common diy thread on top of the gen tech help forum and open the link for checking engine codes.
Old Jul 2, 2012 | 01:41 PM
iStagl's Avatar
Fished my igniter out and took it to Autozone, they tested it for me. They tested it 5 times and it passed every time. Does this now mean it's my coil?
Old Jul 2, 2012 | 02:15 PM
  #17
Silver6gen's Avatar
No, your igniter could function fine when it’s cold, but once the car is warm and the igniter gets hot it can fail. So if they test it when the car is stalled you might have more luck in understanding if it is the igniter or not. Then again it’s hard to plan on where your car will stall…. I know this all too well.
Old Jul 2, 2012 | 06:43 PM
  #18
If you don't wan't to waste money on a part that you aren't sure is the problem, I would go to a U-Pull-It junkyard and buy a coil and/or igniter. You would need ones from a 94-97 LX/DX accord. It shouldn't cost too much.
Old Jul 2, 2012 | 10:37 PM
  #19
iStagl's Avatar
My car doesn't start at all, hot or cold. It just cranks.
My coil i'm getting is only $40, and returnable.
Old Jul 10, 2012 | 08:43 PM
  #20
iStagl's Avatar
Well installed the new coil and surprise surprise there's no fire. After trouble shooting I decided to see if the rotor on my distributor was moving because I wasn't sure if I had put it back on wrong. Then I came to find out my cam wasn't spinning. Yay for broken timing belts.
