Engine Fitment
Old Apr 2, 2007 | 08:47 PM
david76008
Default Engine Fitment
OK Guys, as some of you know, I need a new engine. I found one out of a 92 Accord. Unknown of mileage, and what type of engine, but it IS a 4 cylinder.
Just curious if it will fit my 96 Accord.
Old Apr 2, 2007 | 09:01 PM
sir_nasty's Avatar
Default RE: Engine Fitment
it's going to be an f22a series and your accord ran an f22b series but it should be an easy swap.... I don't know for certain if all the motor mounts will be right though....
Old Apr 2, 2007 | 09:09 PM
david76008
So that 92 motor should be an F22a? Mine is an F22B2.
Could that Accord be a different 4 cylinder?
Old Apr 4, 2007 | 03:20 PM
david76008
Will the Non-Vtec work just as fine?
I just got off the phone with a Junk-yard, and they are saying the 2000 Accord Vtec engine WILL fit. Says to even bring my own distributor to show me.
Is this true guys?
All I know about the engine, is that it has low miles, and it came from a 2000 Accord with Vtec.
Old Apr 5, 2007 | 01:31 AM
blinkin
What engine is in the 93 Accord?
Old Apr 5, 2007 | 05:53 PM
Shadow1992's Avatar
90-93 Accords had the F22A series. F22A1, F22A4, or F22A6. All non vtec, all SOHC
Old Apr 5, 2007 | 09:30 PM
sir_nasty's Avatar
ORIGINAL: david76008
That accord is a different 4 cylinder kind of.... 94-97 accords came with a couple of engine choices, most notably, a SOHC Vtec and a non-vetc choice, the EX had the SOHC Vtec motor....
Old Apr 6, 2007 | 03:03 AM
david76008
If I put a 00' Accord EX engine, will the tranni line up?
I already asked around, and engine mounts up right. Just worry about the tranni. And also been told to get the ECU just in case
GT03 TJS
Dec 26, 2007 09:48 PM
daytonphotog
Jul 12, 2007 11:25 PM
qnguyen209
Feb 18, 2007 05:39 AM
BLuEPiTBuLLz
Feb 9, 2007 02:44 AM
F23AccordLX
Mar 1, 2006 08:13 PM
