engine light
Old May 17, 2005 | 10:45 AM
accorddriverc's Avatar
Default engine light
My check engine light came on fridaynight, so I took it to the dealer saturday morning. They told me it was an intermittent thing but then they suggested( but didn't say I needed) to change spark plugs wires distributor cap and rotor. So I'm thinking ok they want me to get a tune up so I ask how much for all this and they quoted me $711 [sm=smiley3.gif] I didn't get it done but I guess I will need to soon. The thing is I know my sprak plugs can't be bad because I just changed them about a month ago. What do you guys think?
Old May 17, 2005 | 11:04 AM
6thgen's Avatar
Default RE: engine light
What year car? Also did you change the dist cap and wires w/ the spark plugs?
Old May 17, 2005 | 10:07 PM
Burn69's Avatar
Did you replace the plugs with regular ones or platinum ones?
Old May 19, 2005 | 11:24 AM
its a 2000 and the plugs were changed to platinum. But the dist and wires were not changed. The pcv ??? was changed also
Old May 19, 2005 | 11:34 AM
6thgen's Avatar
ORIGINAL: accorddriverc
For future reference...don't waste dough on platinum plugs. They don't spark any better than normal, plugs. It only takes one strong spark and keeping your plugs fresh does that.
Old May 19, 2005 | 05:22 PM
ok thanks. So what about the stuff the dealer "suggested" If I do it I was going to buy the parts and let another mechanic do it
Old May 21, 2005 | 11:50 PM
Burn69's Avatar
Thats up to you..I dont see why you would necessarily need to do it unless you deem necesary....especially when they said it was a suggestion...ie money for them for you to have them do it...
Old May 22, 2005 | 11:48 AM
Evlampius's Avatar
ORIGINAL: 6thgen
disagree - not only would I recommend platinum plugs but also recommend investing in +4 platinum contacts - I see no problems run 50.000 miles on platinum +4 set. That is a smart investment.
AS for the post itself - please visit local AutoZone store and read the code from the computer (check engine light ON) please provide us with the code number - we'll start from there.
I'm not surprised hearing that a dealer charges 700$ for a tuneup while other shops charge $200
after all , you have to support the owners yacht and florida condo don't you?
Old May 23, 2005 | 10:16 AM
ORIGINAL: Evlampius
ORIGINAL: 6thgen
lmao @ yacht and condo. Can autozone still get a code if the light is no longer on?
Old May 23, 2005 | 06:24 PM
Evlampius's Avatar
if the code has been cleared no - if it went away by itself yes - you can read the last one in memory
