Engine Problem
Old Feb 6, 2013 | 08:07 PM
SLIPKANOT's Avatar
Unhappy Engine Problem
Today I came out of a turn and put the hammer down in my 02 Accord EX Automatic with the V6 VTEC. All of a sudden I noticed my check engine(Not Maint. Required) light came on along with my TC light. It didnt seem to be running different until i came up to a light and on my normal take off it sputtered and seemed like it died. I took it to Autozone and the computer said there was noise on top dead center on cylinders 1 and 2 i believe. It also said there was a Transmission shift senser malfunction. I started the Engine and listened to it with the hood popped and there is a knocking sound that comes from the top of the engine like in the valve covers. It gets worse as i rev up. I really hope im not going to have to spend a fortune to get this fixed. I was told it might need a Lifter adjustment. Any other ideas. Please help. I love my car
Old Feb 6, 2013 | 08:35 PM
You really need to post the actual code on here and not the description. They start with the letter P and have four numbers, like P1234.
Old Feb 7, 2013 | 08:38 AM
SLIPKANOT's Avatar
Well I don't have the codes. Just the descriptions. I took it to a mechanic this morning to get it looked at. I am debating whether I should have taken it to a Honda dealership. Either way I need my car back. That Vtec is amazing
Old Feb 8, 2013 | 02:34 PM
SLIPKANOT's Avatar
The mechanic didn't find an issue but I know it sounds funny in the engine compartment. I will be taking it to a dealer eventually to get it looked at. Also I have been getting around 23 mpg. Is that normal for the v6 Vtec
Old Feb 8, 2013 | 03:26 PM
shipo's Avatar
Twenty-three miles per gallon could be spot on, high, or low; it all depends upon your driving style. I get in the low thirties in my 2001 V6 Accord when it's all highway driving and in the low twenties when it's all city driving.
Old Feb 8, 2013 | 05:56 PM
SLIPKANOT's Avatar
Cool Gas Mileage
I drive 30 miles to and from work. Most of my drive is at 60 to 65 mph with the cruise on. Even when i drive all highway it is around 24 to 25. It has a lot of miles on it and im sure it needs some engine maintenance. All the previous owner did was install cold air intake. I was thinking some engine treatment couldnt hurt
Old Feb 9, 2013 | 12:35 AM
phantom699's Avatar
the loud tap means you just need a valve adjustment.. take the head off and theres a tool you can buy for 20-40 depending on where you go, just find the spec's and do it yourself, i think there is a guide on the forums also to do it urself
* be forewarned, if you mess up doing it urself u are ****ed*
Old Feb 9, 2013 | 07:46 AM
You don't take the head off for a valve adjustment. That would be the valve cover.
Old Feb 9, 2013 | 03:21 PM
SLIPKANOT's Avatar
I'm not sure how hard that is. I've never done engine work on a Honda. I've done quite a bit on the Gm's 3800. A Honda dealership near by told me they will probably charge around 200 to 250
Old Feb 9, 2013 | 05:17 PM
Taking the valve cover off is easy. Adjusting the valves is not a bad job, but you should get a shop manual (download via "common DIY" thread).
Removing the head is a big job and you just don't do that for valve adjustment.
However, from the top of this thread I'm not sure a valve adjustment is going to fix your car. Sounds like there's more going on, but maybe some V-6 owners will chime in.
