Engine Stalls when accelerator is depressed
Old Oct 29, 2008 | 07:18 PM
ssanders
Default Engine Stalls when accelerator is depressed
I have a 1997 Honda Accord V6 with 165,000 miles. I got into a front end collision and smashed the radiator and crumpled the hood pretty good. I have fixed all that enough to be driveable. The car sat for about two months without being started. When the car was sitting the sides of the hood were not flush with the body and I think the inside of the engine bay got a little wet. Ok so after I pulled the radiator support out and replaced the radiator and radiator fan, I tried to start the car and no go the engine would turn over but wouldn't start. I replaced the distributor cap and the car started but idled like crap. I had someone come look at the car and he thought it was the crankshaft position sensor because as soon as the accelerator was depressed the car started to stall and the injectors were turning off (he checked them with a injector tester). I had another guy look at it and he said that most likely it was the distributor becuase crankshaft position sensors rarely go bad and that wouldn't turn off the injectors. So I replaced the distributor and I still have the same problems. Can anyone give me some insight on what might be wrong. I haven't had the fuel pump checked but with a pressure gage but i took the fuel line off and wasn't able to hold the gas in so it seems it has enough pressure. I am really stumped here and any help would be appreciated.
Old Oct 29, 2008 | 08:27 PM
Default RE: Engine Stalls when accelerator is depressed
I would short the service connector and see if any codes are stored on the ecu. Follow the instructions to retrieve the CEL codes from the dhost link in the thread titles ACC 5TH GEN..... in the DIY forum.
Old Oct 29, 2008 | 08:35 PM
hondadude's Avatar
The MAP sensor and TPS are the primary items that signal the ECU to advance timing and change injector pulse.
I suggest you look carefully for any part of the wire harness that may have been damaged in the wreck, and also check all fuses.
Has anybody scanned for stored codes?
CPUNeck
Feb 17, 2013 09:28 AM
LadyHonda
Jul 25, 2012 08:17 AM
Donda
Oct 11, 2010 08:42 AM
91boz
Sep 22, 2008 07:38 PM
robracing671
Dec 18, 2007 07:16 PM
